Yesterday I tried some 3m pacing tape. I used one small piece to join the splice and a much longer piece on top. I removed the original adhesive with a small wire brush on a drill and cleaned it up with lacquer thinner then blew it dry. First attempt was a fail. Second try included adding some heat and then clamping. I figured the heat might help the glue penetrate the material. This worked well until the belt was put to metal where, guess what"? The glue heated up and let go. I'm a certified idiot Btw.
What irks me is that nobody can find out what type of glue manufacturers use. According to the research I've done no manufacturer will share this information.
Obviously the makers use a glue that doesn't need 6 days to dry while holding your tongue a certain way. Im sure it's some sort of heat activated adhesive that can withstand the heat that's generates during normal use. I've never had one separate at the seam unless it was old and about to let go like those sitting in my drawer.
On a good note I discovered the Dotco sander I bought for $15.00 sells for over five hundy new. So that's something. I guess?
