I built myself a RPC from a kit. I also used an instructions to install balance capacitors in it. I have 20a 220v 1ph plug, with a 5hp 3ph motor as the idler. With much fussing about with caps, I got the no-load 1ph amps down to 2.7a as read on a amp-clamp.
Now, my aircompressor tank died it rusted out. I need something to replace it.
By looking at electric motor HP charts & amps, and with 20a 1 ph available (less 2.7a overhead) that leaves me a 17.3amp availability? correct?
The charts telling me 3hp 1ph is 18amp and should work straight up 1ph.
The charts telling me 3hp 3ph is 10amp, for total 12.7amp with RPC (so, I can run 3hp 3ph for 5amp less, correct?)
The charts telling me 5hp 3ph is 15.2amp, plus RPC is 17.9 amp. (so, I can run 5hp 3ph for same amp as 3hp 1ph???)
The charts & amps tells me it will work, but can I really run a 5hp motor on a 5hp RPC?
I've looked at RPC with amp clamp and watch my mill & grinder ramp up the amps, it is the same baseline 2.7a plus the nameplateamp on the motors. this much math does add up. mill an grinder are 1hp an .5hp respectively.
