I was making some stepped bushings that needed tapping. They were about 3/8 or 1/2 inch long , and the internal thread was 8 /32 or so.
I made a holder from bar stock, with a slit end. The parts were loaded from the bottom, which meant pushing them up with a tool while clamping the slit part.. so one hand to tighten. Anyway this was years ago, but to close the slit and clamp the work , I used a skewer rod and clamp , from a bicycle. The type with the flip over lever.. it worked really good .. surprisingly well. I left it full length but it can be shortened. ,
Just thought it worth mentioning as it could help someone else.
