A quick path to grinding my brazed carbide tools
  • #16
    High speed produces heat and I have heard that diamonds plus heat burns the diamonds away. There goes your expensive diamond wheel. This seems to be a very good argument for using a high speed, diamond wheel wet to keep the temperature down. Possibly a good argument for slow speed for diamond wheels as well.
    I have a slow speed grinder with a non-diamond wheel. It has a built in water bath and it works well. The wheel seems to stay cleaner and I have no problems with overheating the objects being sharpened. I really like that. If I were to make or buy a machine with a diamond wheel, and I do need one, it would probably be both slow speed and have a water bath built in.
    If I am wrong, go ahead and blast away.
    And yes, the OP's repurposed grinder does look like a nice idea. Just use it wet.
    This reminds me that I need to sharpen the kitchen knives again.
    Hi,
    That's not a real issue with resin bonded diamond wheels. The bond will break down and the diamonds will fall out ages before they will dissolve or get burned away. Had a Darex Endmill sharpener that we were constantly using to regrind the sides of 3/4"x 6" HSS endmills with. Nice and pricey name brand white aluminum cup wheels might last a month of use. We switched to resin bonded diamond wheels and we could get 8 to 12 months worth of daily use from one wheel and that was with a 1750RPM motor and run dry with no coolant system.
    With a proper diamond wheel set in the correct bond, speed and coolant don't seem to be to much of an issue. Even with a Cheap, Cheerful, Chinese made diamond cup wheel, one should get pretty darned good service at home on HSS or carbide.
    • #17
      The prognosis is promising... That's a piece of #8 (maybe #6?) wire I'm using as a flexible spout positioner. There is a pinch control that allows anything from full flow to an occasional drip. (I'm a Doctor, Jim, not a machinist!)
      • #18
        Very ingenious. Love what you did there.
        I use diamond for slow speeds or any metal not having carbon Diamond is carbon and gains an attraction to the carbon in the tool.
        For carbon steel I use cbn wheels (same costs as diamond) at high speed. JR
        • #19
          Heh, I'm currently on a PICC line at home, saving up a month's worth of push syringes to use around the shop. Precision oilers, etc.
          PICC line is because I had a intra-cranial abscess (staph) following surgery back in October. There is more than one way to go on vacation.
          • #20
            I am sorry to hear that. I hope you are doing well.
            I had an IV in for a month pushing antibiotics three times a day. The syringes I used were the screw in type. Lol. I saved them also for use in the shop. JR
            • #21
              Bummer. Hope your recovery is speedy and complete. I'm grateful that I was able to get one that I hadn't needed to use myself!
              • #22
                on the topic of diamond and steel: this is a coarse diamond wheel ("kaindl") i have been using to sharper axes, shovels, chisels etc. for about 20 years. i also use it to rough grind hss tools. carbide tools also. no problem putting another relief angle on brazed tools.
