Something followed me home!
  • Something followed me home!
    I'm not sure what I've gotten into, but this thing followed me home yesterday.
    You may only view thumbnails in this gallery. This gallery has 1 photos.
    Vitَria, Brazil
    Tell us what it is.
      I'm hoping you guys can help me learn a little about it. My largest lathe 'til now is a SB 13" tool room style.
      This one is older than I am, has some wear and tear, but I believe it can still do a lot of work.
      I'm not planning a "restoration". Just something to use.
      It has all inch threads and metric threads. The cross slide is pretty tight. The chuck is junk.
      I need to know if it is MT4 or MT5.
      Also, I'm going to post some other pictures of parts that I don't know what are.
      Vitَria, Brazil
        More pictures.
        You may only view thumbnails in this gallery. This gallery has 5 photos.
        Vitَria, Brazil
          The head has some play in it. It seems to a bearing mount. Can these be tightened?
          You may only view thumbnails in this gallery. This gallery has 2 photos.
          Vitَria, Brazil
            What is this for? It seems to have had some kind of motor.
            Vitَria, Brazil
              What does this lever do?
              Vitَria, Brazil
                What is this little box about?
                Vitَria, Brazil
                  I am re posting the other pictures on this thread instead of the "More Pics" one.
                  You may only view thumbnails in this gallery. This gallery has 3 photos.
                  Vitَria, Brazil
                    That lever in post #7 looks to be a clamp to lock the tail stock down to the bed, for example when turning between centers or drilling with a tail stock drill. Likely turns an eccentric that presses a plate up under the ways.
                    (I answered this one because it was the easy one - the others are more mysterious!)
                      That's what I would have thought, but it doesn't seem to lock it down. The big nut on the other side does though.
                      Vitَria, Brazil
                        VDF RO lathe. It is a lever tailstock lock, the front nut needs to be adjusted so the lever accurted cam can tighten against the underside of the ways.
                          Also for hauling it home so the tailstock is still there when you get there. I've run into a couple of people who lost the tailstocks by not locking them down while in transit.
                            Great. That helps. One thing answered. Thank you! Any info about the bearing on the head stock? Or do I just have to take apart and find out?
                            Vitَria, Brazil
                              It sounds like you know this lathe. Right beside where the lever connects is a hole that looks like something was broken off out broken out. Any idea what that might be?
                              Vitَria, Brazil
