Hello. 1st post here. Be gentle please.
I've got a little lathe running a 3 phase motor through a single phase inverter.
I like having the easily adjustable speed.
I'm picking up a considerably larger (huge) lathe in about a week and need to think about how I'm going to power it.
I've got a 3HP induction motor on my bandsaw that could be re-purposed (it's way too big for the bandsaw) but there will be no speed control apart from swapping pulleys on the counter shaft.
I've also got a couple of 2000W brushed motors from some old chopsaws that could be re-puposed. They'd need to be geared / pulleyed way down but that's doable, and the speed can be adjusted via a suitable controller.
I know I could get a big 3 phase and an inverter but I like to work with what I have (if possible) but I'm open to all suggestions.
Also, I like to go cheap if possible!!
Has anybody here used a brushed AC motor to run a lathe?
Any opinions would be most welcome.
Thank you.
Thank you.
