Improvised Bigger Tap Wrench
  • Improvised Bigger Tap Wrench
    I had to twist a tap a little bigger than the capacity of the largest tap handle I had on hand. Two wrenches saved the day!
    Well done, add big tap wrench to the to do list!
    mark
      Well, that's using the old noggin.
      "I don't need no stinking tap wrench!"
        Heck yeah! Nailed it. I like to see posts like yours Sir. Thanks.. JR
        Umm? you beveled the holes before tapping right? Cause that is what it looks like and that is the way to do it, IMO. JR
          Good thinkin'! I don't think I'd dare try that with a small tap - Of course you normally wouldn't need to (unless you lost your tap handle?).
            Nice to see someone else with my bad habits. Thanks !
              The only problem with that setup is you need four cresent wrenches. Two imperial wrenches and two metric wrenches. In this day and age even here in Germany we have imperial stuff and metric stuff so you have to be prepared.
                Nice improv. That just gave me the idea that you could weld a coupling nut to the outside jaw of an adjustable wrench so you can screw in a handle for the other side when needed. I've got a few surplus adjustables that are expendable for this.
                  I've got a whole drawer of assorted metric/imperial crescent wrenches. They're in the drawer right above my metric and imperial hammers!
                  Oregon, USA
                    My metric hammers are indistinguishable from my metric crescent wrenches.
                      Mitutoyo used to make two sets of telescopic bore gauges, one metric and one imperial, in their catalogue from the 90's.
                        Is this one of them?
                          I'm envious! Thats gorgeous!
                          Oregon, USA
                            I can't tell. I told you they are indistinguishable.
