A little gear help please
  • A little gear help please
    My gear cutters are 24DP. Many people want to build my engines, but have 32 dp or 48 dp gear cutters. If my engine plans call for a 2:1 ratio and 1.563" center distance, this works out fine using a 25 tooth gear and a 50 tooth 24 dp gear. Are there combinations of other gear sets that will still give 2:1 ratio and 1.563" center distance?----Brian
    Design engineer
    Barrie, Ontario, Canada
    DP is teeth per inch of diameter.
    So going from 24DP to 48 DP, the tooth count doubles, and the size stays the same. At least the pitch circle does.... the OD will be smaller due to the tooth size lowering the "addendum" outside of the pitch circle.
    The OD will be a bit less, but that will not affect the spacing, which is based on the pitch circle.
    2801 3147 6749 8779 4900 4900 4900
    It's just a box of rain, I don't know who put it there.
      Unfortunately the pitch diameter is fixed by the tooth form.
      Pitch diameter = # of teeth/Pitch
      25 teeth/24 dp = 1.041 PD
      50 teeth/24 dp = 2.083 PD
      You need to calculate different combinations that result in the same PD's
      This is an excellent gear resource, enter the # of teeth and the DP and it will give you the relevant dimensions plus CAD drawings.
      https://www.rushgears.com/tech-tools...lacement_parts
        Also, how did you calculate the center distance?
          Center distance for mating spur gears is equal to 1/2 the pitch diameter of each gear, added together. My first post had an incorrect center to center distance in it. I have edited that to correct it.----Brian
          Design engineer
            How did you arrive at 2.970?
              Bented--My first entry was wrong. I have edited the center to center distance to 1.563". For 32DP gears, a 32 tooth and 64 tooth would give a 2;1 ratio and a 1.563" center distance.
              Design engineer
                As I had suspected, thought that I had miscalculated on my end.
                  Brian, have you ever heard of gearotic motion software? Its intended for cutting gears on a cnc machine BUT it gives all the dimensions, center distances and much more as well as a drawing of the gears, even animates them. You can print the gears out at 1:1 also which is very handy. Its very easy to use and there is a free trial. Its perfect for this sort of what-if sort of engineering. First gears I made were helical 90 degree drive and worked out perfect first time. Along with gears, it does ratchets, sprockets, timing pulleys and much more all of which could come in handy for your engine building.
                  Its basically a simple to use cad especially for gears.
                  https://www.gear2motion.com/
                    I've heard about it Sparky, just haven't used it. I will save the link and try it out. Thank you.---Brian
                    Design engineer
                      Is it possible? Yes. And No.
                      You have two 24 DP gears with 25 and 50 teeth. And as you and others have said, their PDs are 1.0417" and 2.0833". This comes from the equation:
                      PD = N / DP
                      N = Tooth Count
                      When you work this backwards, you want to keep those two PDs the same so the gear spacing and the gear ratio both remain the same. So you need to use those two PDs for your calculations. Notice that these two PDs have the desired gear ratio of 2::1.
                      2.0833" / 1.0417" = 2
                      So keeping those two PDs, and trying to switch to a different DP we rearrange the equation above into:
                      N = PD x DP
                      That is the same equation, but it is rearranged.
                      So for 48 DP we get
                      N = 1.0417 x 48
                      and
                      N = 50 for the smaller gear
                      and
                      N = 2.0833 x 48
                      and
                      N = 100 for the larger gear
                      There is a small rounding error in both of these, but that is all it is, a rounding error. Two 48 DP gears with tooth counts of 50 and 100 will fulfill the stated conditions: a 2::1 gear ratio and a 1.563" center distance. That center distance is exactly the same as your original 24 DP gears. So there is your "YES".
                      But if I carry out the same calculation for 32 DP gears I get:
                      N = 1.0417 x 32
                      and
                      N = 33.333 teeth for the smaller gear
                      and
                      N = 2.0833 x 32
                      and
                      N = 66.666 for the larger gear
                      And since you can not have 1/3 or 2/3s of a tooth, you can not use a 32 DP for your substitution.
                      32 DP is a definite NO.
                      So, what DPs will work?
                      You will need to scale your DP (24) by a factor that will also scale your tooth counts (25 and 50). Notice that 48 DP is exactly twice your 24 DP and the tooth counts for a 48 DP gears are twice the original tooth counts or 50 and 100. That works. In fact, we can multiply the original 24 DP by any whole number (2, 3, 4, 5, etc.) and the tooth counts by that same factor and it will work.
                      But are those multiplies all the additional DPs that will work. We can pick any two whole numbers that give the same 2::1 gear ratio and then calculate the DP. As an example, 13 and 26 teeth.
                      We turn that same equation around in a different way to solve for the DP:
                      PD = N / DP
                      becomes
                      DP = N / PD
                      And solving for DP we get:
                      DP = 13 / 1.0417
                      DP = 12.4796...
                      and
                      DP = 26 / 2.0833
                      DP = 12.4796...
                      That is not a DP that you are going to easily find any cutters for, but it is a valid DP. And cutters could be made. Some gears have been made in exactly this manner: start with a shaft spacing and a desired gear ratio and calculate the needed DP. Then they make the cutters and make the gears with them. It can solve some design problems.
                      This is probably the way that any ratios that are not whole number multiples of 24 is going to turn out. The three numbers we are working with are 24, 25, and 50. These three numbers do not share any common factors. So it is probably impossible to find any additional factors other than the integers I listed above that will result in a whole number for the DP.
                        Bented, what you say appears to be wrong, if I am understanding your statements. You appear to be confusing the OD and the Pitch Diameter.
                        The OD is affected by tooth form etc. The PD is not. Where do you see any reference to tooth form in the PD equation?
                        The 50 tooth 48 DP gear has the same pitch diameter as the 25 tooth 24 DP gear, for instance. The actual OD will be different, because the tooth is smaller with a 48 DP gear, and the fixed addition of 2 teeth is not "proportional".
                        But, the center to center distance should be OK, depending on the allowance that was given for clearance. The smaller tooth will give a different clearance (backlash) for the same C-C allowance.
                        The basic starting point for determining C-C distance is the pitch diameters, which theoretically touch with perfectly mated gears of perfect form.
                        So doubling the DP and the tooth count will in fact be fine, depending on the extra allowance given for backlash (clearance). Going that direction the OD should be OK as well (halving the DP and tooth count might not be).
                          Modulous 2 gears are an exact fit for your needs. 13 and 26 teeth
                            If you like spreadsheets you can run through the combinations using the formula DP=(3xteeth)/(2xspacing) where teeth is the smaller gear. This formula is specific to the 2:1 ratio needed for camshafts of course. You don't get many whole number DP results but a few like 33 teeth gives 31.7DP. Is that close enough to 32 to use the same cutter? Probably for this aplication as the cutters are approximations anyway.
                            You could rearrange the formula to give teeth for a given DP but you just end up with fractional teeth which are rather weak.
                            For your next engine please start with a design criterion of gear spacing exactly 1.5in which works everything out perfectly with small gear teeth = DP.
                              The center distance between two gears is
                              C = (D_G + D_P)/2
                              where D_G and D_P are the pitch diameters of the gear and pinion.
                              Knowing that D = N/DP you can write this as
                              C = (N_G + N_P)/(2*DP)
                              where N_G and N_P are the tooth numbers of the gear and pinion.
                              For your specific gear set, N_G = 2*N_P, so this reduces to
                              C = (3/2)*N_P/DP
                              Your center distance C = 1-9/16" = 25/16", so the number of teeth on the pinion is
                              N_P = (25/16)*(2/3)*DP = (25/24)*DP
                              or N_P = 25 for a DP of 24.
                              For any other diametral pitch with a center distance of 1-9/16", the number of teeth on the pinion is N_P = (25/24)*DP, which must be a whole number. This will only work for other whole-number (not fractional) DPs that are multiples of 24. For a DP of 32, this gives the N_P = 33-1/3, clearly not a whole number.
                              As Baz pointed out above, if you would have used a center spacing of C = 1.5" (3/2"), then the number of teeth on the pinion for your 2:! ratio is N_P = DP, which works for any whole-number diametral pitch.
