Hi all,
I need help on how to lubricate my Prazi SD300. I know how to lube most components but haven’t figured out how to lube the following:
-Leadscrew thrust and slide bearings
-Drivetrain stepped V belt pulley – the manual shows it is to be oiled before every use but there is no oil hole or lube fitting.
This pulley can be taken off its shaft by removing a snap ring but I wouldn’t think that would be done before every use. So how is it supposed to be lubed?
-Are there any other lube points in the drive train?
Thanks,
henryr
Thanks,
henryr
