I keep a bottle of liquid dish soap at my wash sink. It cuts the grease very well. I don't use any of the handwashing liquids with ground pumice in them because my wash sink drains into a sump and is pumped up thru a check valve into the septic bed.
GoJo/Goop hand cleaner dispenser
Originally posted by nickel-city-fab View Post
That's because many don't know about the "benefits" smooth kind, as opposed to the kind with 60-grit rocks in it.
Ooops. I work in one of those jobs where you wash you hands *before* you pee.
The only one I’ve tried that I like more was some stuff from Germany called Kresto. I think, anyway.
We tried many more. Some were slightly better but were hard on the skin.
I washed my hands before peeing so long that even now I have to pee every time I wash! For me the ultimate test was if the cleaner would cut the godawful nasty oil from a “Green Grenade”. Also known as a Detroit Diesel.I cut it off twice; it's still too short
Oregon, USA
- 2 likes
Visit a pub. Maybe they'll give you a wine bag or similar. Empty of course- or you sit and drink until it is empty-
What else have I seen- some of the coffee dispensers use bagged product. You might be able to buy milk in bags. Just look for a decent spout that you can fill through and dispense from. Preferably one with a valve of some kindI seldom do anything within the scope of logical reason and calculated cost/benefit, etc- I'm following my passion-
Odd.... I have been cleaning up machinery, and the orange container goop works just fine. Better that it has no grit in ot, since that crap can transfer off your hands, and there WILL be some left2801 3147 6749 8779 4900 4900 4900
It's just a box of rain, I don't know who put it there.
Originally posted by Bob Engelhardt View Post
Uh ... no -it will! Have I given you the impression of being so stupid that I would leave the lid off?
or find complicated solutions to a simple problem. But it also takes
perspective and discipline to dial back the creativity and distill it down
to a practical solution.
-D
DZER
- 1 like
Originally posted by nickel-city-fab View PostAt work, I start my cleaning with a splash of diesel and a rag to get the worst of it, then follow up with D&L hand cream and a fresh rag to get most of it. Enough to where you can see your hands again, and not leave a greasy crust on the steering wheel.
But a greasy wopper and fires cleans hands like nothing else.
And thank God that low sulfur diesel smells less than the diesel of years ago.
-DoozerLast edited by Doozer; 02-18-2021, 10:37 PM.DZER
- 1 like
Originally posted by nickel-city-fab View PostHand cream is good for more than just hands. I've used it to clean small parts, clean hoses, and scrubbed it into my clothes before they go in the wash. My new job can be especially dirty and uncomfortable and cold, so I made them buy me coveralls.
I think it was epoxy with carbon graphite matt. So kept the epoxy from sticking to your arm or hand. I dont know, something like that. Google it on upJR
I think it's typical for that hand cleaner to separate over time. I've had it happen with the Go Jo stuff. I've used Fast Orange for years now, comes in gallon jugs with a pump handle. When the contents get below the pump stem, usually a year or more for me, what's left in the bottom looks somewhat clear but still works just as well. I've found it best to shake the jug up a couple times a year. A pump handle is a lot cleaner and easier to use than dipping your fingers into a can.
JL............
Originally posted by Doozer View Post...
Man you guys would complicate taking a piss.
-D
Unless you just piss out a window, then, yeah, it's not so complicated.
Originally posted by brian Rupnow View PostI keep a bottle of liquid dish soap at my wash sink. It cuts the grease very well. I don't use any of the handwashing liquids with ground pumice in them because my wash sink drains into a sump and is pumped up thru a check valve into the septic bed.
I avoid the pumice stuff for a similar reason. For tough gunk, try mixing a bit of granulated sugar with your dish soap. The sugar stays crystalized long enough to give your skin a good scrub.
The best hand cleaner I have ever used is "Power Cleanse Hand Cleaner" made by Texas Refinery Corp. A little bit goes a long ways and it's very easy on the skin. https://www.texasrefinery.com/produc...power-cleanse/
Let's consider the complicated-ness of pissing: you go into a special room & use a highly specialized device. Made of porcelain, with automatic refilling, & perhaps costing hundreds of dollars. And installed to comply with quite specific regulations. The procedure involves a number of steps where deviation can invoke wifely criticism (inaccurate aim) or embarrassment (failing to zip up).
This was indirectly a goal in my life.
-DoozerDZER
Back in the day, I used to sell Kresto, and Solopol, the weaker version, that was made by Stockhausen, a German company. Both of them used ground walnut hulls for grit. Main advantage was it didn't scratch or cut like pumice did, it floated and didn't clog sinks, and had sulfonated castor oil as a moisturizer. When I started my cleaning business, had a few customers who complained about what they were using, started them on Kresto, when I retired, had to tell them where they could get it. Bought several cartridges of it when I retired, about five years ago, and two that are left have not separated.
