GoJo/Goop hand cleaner dispenser
  • JRouche
    Hand cleaners? I grew up using Comet cause thats what my dad used. Not Ajax (too soft), Comet. Hey, it works and I like the smell of bleach.
    When I had a couple extra bucks I tried "scrubs in a bucket". That stuff works very well too pricey for my comet hands JR
  • JRouche
    Originally posted by Bob Engelhardt View Post
    Unless you just piss out a window, then, yeah, it's not so complicated.
    Come on... Doozer has to have at least one window in his house. I had a neighbor here in the burbs that would piss in his backyard just cause he thought it was "cool". JR
  • Corbettprime
    Back in the day, I used to sell Kresto, and Solopol, the weaker version, that was made by Stockhausen, a German company. Both of them used ground walnut hulls for grit. Main advantage was it didn't scratch or cut like pumice did, it floated and didn't clog sinks, and had sulfonated castor oil as a moisturizer. When I started my cleaning business, had a few customers who complained about what they were using, started them on Kresto, when I retired, had to tell them where they could get it. Bought several cartridges of it when I retired, about five years ago, and two that are left have not separated.
  • Mcostello
    Battle Axe has the coolest name for hand cleaner. Eco works well. Zep cherry is good also. Tried a lot of brands over a couple of years.
  • Doozer
    Let's consider the complicated-ness of pissing: you go into a special room & use a highly specialized device. Made of porcelain, with automatic refilling, & perhaps costing hundreds of dollars. And installed to comply with quite specific regulations. The procedure involves a number of steps where deviation can invoke wifely criticism (inaccurate aim) or embarrassment (failing to zip up).
    I own enough land, that I can piss any direction and not see neighbors.
    This was indirectly a goal in my life.
    -Doozer
  • Arcane
    The best hand cleaner I have ever used is "Power Cleanse Hand Cleaner" made by Texas Refinery Corp. A little bit goes a long ways and it's very easy on the skin. https://www.texasrefinery.com/produc...power-cleanse/
  • Galaxie
    I keep a bottle of liquid dish soap at my wash sink. It cuts the grease very well. I don't use any of the handwashing liquids with ground pumice in them because my wash sink drains into a sump and is pumped up thru a check valve into the septic bed.
    Brian,
    I avoid the pumice stuff for a similar reason. For tough gunk, try mixing a bit of granulated sugar with your dish soap. The sugar stays crystalized long enough to give your skin a good scrub.
  • Bob Engelhardt
    Man you guys would complicate taking a piss.
    -D
  • JoeLee
    I think it's typical for that hand cleaner to separate over time. I've had it happen with the Go Jo stuff. I've used Fast Orange for years now, comes in gallon jugs with a pump handle. When the contents get below the pump stem, usually a year or more for me, what's left in the bottom looks somewhat clear but still works just as well. I've found it best to shake the jug up a couple times a year. A pump handle is a lot cleaner and easier to use than dipping your fingers into a can.
    JL............
  • JRouche
    Hand cream is good for more than just hands. I've used it to clean small parts, clean hoses, and scrubbed it into my clothes before they go in the wash. My new job can be especially dirty and uncomfortable and cold, so I made them buy me coveralls.
    Ok. Shark has Jumped. Hand Cream. Wow.. And, it has some release agent in it so your hands or other parts wont get stuck.
    I think it was epoxy with carbon graphite matt. So kept the epoxy from sticking to your arm or hand. I dont know, something like that. Google it on up JR
  • nickel-city-fab
  • Doozer
    At work, I start my cleaning with a splash of diesel and a rag to get the worst of it, then follow up with D&L hand cream and a fresh rag to get most of it. Enough to where you can see your hands again, and not leave a greasy crust on the steering wheel.
    D&L is way better than goojoe.
    But a greasy wopper and fires cleans hands like nothing else.
    And thank God that low sulfur diesel smells less than the diesel of years ago.
    -Doozer
  • Doozer
    Uh ... no -it will! Have I given you the impression of being so stupid that I would leave the lid off?
    No actually a trait of very high intelligence is to want to boil the ocean,
    or find complicated solutions to a simple problem. But it also takes
    perspective and discipline to dial back the creativity and distill it down
    to a practical solution.
    -D
    Odd.... I have been cleaning up machinery, and the orange container goop works just fine. Better that it has no grit in ot, since that crap can transfer off your hands, and there WILL be some left
    Visit a pub. Maybe they'll give you a wine bag or similar. Empty of course- or you sit and drink until it is empty-
    What else have I seen- some of the coffee dispensers use bagged product. You might be able to buy milk in bags. Just look for a decent spout that you can fill through and dispense from. Preferably one with a valve of some kind
