It wouldn't be for everybody, but it might be an interesting way to do it. Cordless drill with a base unit, a holster kind of. When you put the drill down it charges. Pick it up and use it, put it back down it charges. No battery to go bad. Extremely fast charge. Should be cheaper than replacing batteries- but the charger will cost as well. Might be an option for drills that are fine, but that you'll never find batteries for.
Where are we at now with super caps? I read somewhere that we're up to about 1/5 the energy density of batteries, so that doesn't seem too anemic for this application.
This is probably not very good for portable applications, but in a home shop it might be ok. I probably have at least a dozen drills that are great tools, but too old to replace batteries for. Granted- it would be a lot of work to build a super cap array onto every drill, and to provide a pair of high current connectors for charging. And then the charger-
Ah, it's probably a stupid idea- but I'll leave it here.
