The best way to approach this problem is one step at a time.
1) Add ONE cable (without the scale attached) and check for issues.
2) Remove that cable, then attach the other cable and check again. If either cable exhibits problems, swap it to the other axis input and retest.
3) Add a scale to the one cable hooked up and retest.
4) Remove that cable and scale and hook up the other set and retest. If either scale exhibits the problems, swap axis inputs and retest.
Take notes so that you don't inadvertently test the same setup twice and make incorrect conclusions.
