Hello all,
I've posted a few pictures in the "What Did You Machine Today?" Thread thread (https://bbs.homeshopmachinist.net/fo...-machine-today) and I was asked to post a build thread. While this is rather belated as the lathe was started about 2 years ago today, here it goes.
The shop I have is very small and hard to reach as it's in my basement. Some years ago I was very, very busy making and selling a product and would have loved to have a production lathe that could be moved into my shop, make small parts, have a 5c collet, and didn't take up much space. At the time, the Tormach Slant-Bed lathe wasn't yet released. Even if it was, it would have been a little large for my needs. So, about 2 years ago, we started this lathe build with the goal of having the following features in as small a space as possible:
- Is small enough that it can be carried by two people.
- With the exception of a computer for CNC operations, there should be no other external components. The frame contains everything from the turret to the electronics.
- Has a 16 position turret for tooling.
- The spindle takes standard 5c collets with stock up to 1″ in diameter through the spindle.
- The spindle has an electrically operated collet closer that is controlled by the computer.
- Uses a common 115 VAC power cord.
- Has threading and rigid tapping.
- Uses a variable speed motor.
