Suppose you mix water with antifreeze- lets say equal volumes of each. The result is a volume less than two parts. Making a metal alloy probably does the same thing- yes or no?
I expect the total weight to be the same- at least to within a very small deviation if at all.
If I melt together one cc of lead and one cc of tin, will I get 2 ccs of solder?
