[QUOTE=dian;n1932171]oh, i completely forgot induction hardening.
sometimes things happen that actually "should" not happen. its a special case with heating rates up to 1000°c/second and extremely fast quenching (cycle times can be as short as 5 seconds). not too many steels get induction hardened (4140, 4340, 1541 among others) and im led to believe that they somehow (!) lend themselves particularly well to this prozess.
three things happen:
- austenizing temp. increases by 100-300°c which considerably accelerates diffusion
- extremely fine austenite grains form under these cicumstances facilitating transformation to martensite
- retained austenite dereases dramaticaly at these cooling rates.
which result in a hardness even several hrc points higher than conventional heat treat.
besides, induction hardening is not really hardening, its rather heat treat, in the sence that the parts usually dont get tempered. you dont expect hrc 60 from the process, so that martensite transformation doesnt have to be "complete". its also important in which state the steel procesed: pherodized, annealed, normalized or hadened&tempered austenize/harden differently in ascending order.
maybe somebody can explain better why it works.[/QUOTE
Daang it!!!
You mage me turn on the electric oven, Most folks dont kwow what 23-24k looks like .
I do. "{ JR
Daang it!!!
I do. "{ JR
