Rod cuttin
  • nickel-city-fab
    I know someone who tried to shorten an allen wrench with a HSS cold saw blade. It cut it, but the blade was sent out for sharpening the next day.
    Why wouldn't it work on SS as long as you had the corrrect speed and feed combo?
    Every cold saw I've ever used had a carbide tipped blade. Dunno why anyone would use HSS in one.
  • reggie_obe
    Originally posted by Tundra Twin Track View Post
    I don’t know how happy a cold cut blade would be on some real hardened pins or dowels,my friend had a $180 oops with a new Fein Blade that he thought would cut a hardened shaft.He said it took about 2 seconds to destroy blade.
  • Tundra Twin Track
    I still maintain that a cold saw is the way to go. Almost no burr at all, no heat, no sparks...
  • eKretz
    Ditto. Finished ends for most stuff on the initial cut is a big plus in my book.
  • nickel-city-fab
  • dian
    mine are not "elastic" but probably the same, different make up over here. at the local tool store on sale.
  • Bob Engelhardt
    Originally posted by dian View Post
    got a 10-pack for $9 last week.
    Where was that? Amazon is much more. Or maybe a different "model". https://www.amazon.com/69948-Cut-Off.../dp/B079GRB43J
  • dian
  • Tundra Twin Track
    its probably easier to modify an angle grinder stand
    That looks pretty slick dian,I’m sure your familiar with the Pferd 40 thou thick zip blades there the best I’ve ever used.I use the 5” for Alumnium or Stainless on that little chop saw.
  • dian
  • JRouche
    This small Chop Saw works great for one piece at a time,it cuts faster than I expected 1/2 dia max. Click image for larger version
    I will copy some, thank you. JR
  • Bented
    I see that Tormach has a bar fed bandsaw for less then $4,000.00, of course there is no way to know how well it works or if it works at all.https://tormach.com/machines/bandsaws.html
    We do not have a bar fed saw other then low paid laborers, set a stop, advance stock, close vice valve, advance blade then retract blade, repeat as needed.
    Two years ago I set a stop for a new guy with no experience at all, a 20 year old. 1 1/2" dia. aluminum round bars cut 1 9/16" long, showed him what to do, whilst keeping an eye on him running the first few I had a look at the work order, 13,000 parts.
    Saw to rough length
    Face mill, chamfer mill around the OD, drill and tap 1/4-20 X 1/2" deep.
    Face mill other side bringing finished length to 1 1/2"
    Chamfer mill OD
    Mill 1/4" wide X 7/8" deep slot across face
    Deburr
    To his credit he did not quit until they were finished.
    Near the end of the cutting he ran out of stock, someone had failed to allow for the 60+ feet that went into the chips from 13000 saw cuts (-:
  • reggie_obe
    This Greenlee hydraulic tool claims it will shear up to 5/8" rod (plus other shapes). https://www.greenlee.com/us/en/shearing
    Might be a little pricey.
  • gellfex
    Many years ago I built a mini cutoff saw sized for 4" abrasive disks because I was cutting a fair amount of hard shafting. It was timing belt driven from a surplus blender motor. Still works! I made a V-block with clamps and stops for repetitive cuts. It's so crude I am reluctant to post a pic, but gives excellent cuts on stock up to 1/2". A quick touch up on the disk sander are all they need.
    Originally posted by DR View Post
    I have one of the Stanley cutters. I doubt very much it'd cut 3/8" SS.
    Does not need to. It's not really FOR that. In fact, look at it... it likely does not have a HOLE for 3/8"
    The bench shears all have holes for 3/8" rod, and in any case, that size is big enough to use any saw with.
    The hassle making stuff is down in the wire to 3/16" or maybe 1/4" sizes, mostly too small to saw, too hard to hold one piece for an abrasive wheel, big hassle to get the end smoothed if you use nippers, etc. The cutters are for that sized stuff, even 1/4". The shear cuts 3/8", the Stanley goes to 5/16" in.
    The 3/8" SS? It's not for everything (what is?), but it IS "for" a LOT of things.
    The pics are for bolts, I thought there was a similar one for plain rod......
