Very Happy with this Endmill
  • Very Happy with this Endmill
    Got around to using this Ingersoll Endmill and was very pleased how it works,was side milling steel 1/4” cut ,steel was 1/2” thick. Click image for larger version
    Nice ! ! !
    When that shape insert first came out,
    I trued a face mill with them, and I was hooked.
    Best finish and least amount of spline hammering
    out of anything I had used since. They work well.
    --D
    DZER
      If you like those you should try the XOMX. They cut almost like a solid carbide endmill, very smooth. But very expensive.
        Nice ! ! !
        --D
        I think when they came out they called them feed mills.
          What are those inserts called? I tried googling the numbers on the sides of the boxes but got nothing.
            What diameter is that? It appears to be around 1"/25mm. And what diameter is the shank? 3/4? 7/8"?
            I am planning on getting a good indexable end mill, but I was thinking something a bit larger in diameter. Perhaps they make a 2" one with those inserts.
            Originally posted by Tundra Twin Track View Post
            Got around to using this Ingersoll Endmill and was very pleased how it works,was side milling steel 1/4” cut ,steel was 1/2” thick. Click image for larger version  Name:	47BC15CC-404F-40A5-B693-B8AB09C279FE.png Views:	82 Size:	4.72 MB ID:	1932917
              They look to be very similar to the Sandvik 390 / R390 series of inserts. I believe(?) that the generic name for that style may be APKT - might help you in your searching?
              Ian.
                Ian.
                IIRC Sandvik 390, APKT and XOMX are all slightly different from each other and don’t really mix and match.
                APKT is ”defacto” standard for cheap chinese tools.
                SEKT might be also worth a look if you are after face mill only.
                  I have nothing but kudos on this stye of mill cutter. I have a 2 inch wuhanium cheapie on R8 and IIRC it cost around $35. For that price I figured what the hell if it's junk I'm not out much and I clicky'd the ebay gimme button. I run the heck out of it and it works well. It will hog .150 on my 80 year old worn out mill and provide a good finish. As a hobbyist It gets used maybe 1-2 times per month. I bought a couple boxes of inserts for it but I think the OEM inserts seemingly will last another 5 years before I have to flip them..
                    Ian.
                    Yes the O.P. cutter has APKT inserts. They are pretty good and quite smooth cutting. XOMX are not compatible, they are Seco only as far as I'm aware. I don't know about R390, I've never gotten to try those, and they are Sandvik proprietary AFAIK.
                      The Ingersoll site listed them as Multi if I read it correctly.
                      End Mill is 1-1/2” with 1-1/4” Shank coolant through which my Mill is not setup for yet. Click image for larger version
                        These ones aren’t that cheap also,I believe tool around $350 & inserts $17 each US dollars
                          I have some APKT 1003 insert end mills in 1/2", 5/8", and 3/4" and they work great. Bought specific aluminum cutting grade with ground edge and a bunch of coated inserts for steel. Very good results you just have to pay attention to the feedback from the mill and cut to adjust feed and speed rates.
                          While the 1003 are smaller they cut well, just pay attention to what you buy. There are also 1505 and 1604 sized APKT inserts.
                            Thanks for insight,did not know APKT came in other sizes other than 1604 series.
                              No you're right, they aren't. The XOMX in the size I use (1806) are closer to $20-$24 apiece. The cutter (3") is over $800 new.
