Any recommendations for indexable boring bars for a 2" boring head? Minimum diameter holes will be .375" and 1.5" deep.
Boring head boring bars
SCLCR10 bars, cut down and turned to 0.375". They're cheap as chips ($5 each or so) as are the inserts. I bought 3 or 4 of the 12mm ones and cut them to different lengths so I can always use the shortest bar for the cut. If you get an SCLCL bar you can also do the OD of bosses without worrying about your boring head unscrewing.
https://accusizetools.com/products/1...-set-2627-9104
I use these. They work very good. Could turn down shanks if necessary I’m sure.
I think sclcr and similar have the cutting edge above center don’t they? I chose the above because they’re on center and they have round shanks so you can rotate them to the proper angle without working against flat spot on sclcr bar. Of course I could be totally wrong also🤷♂️Last edited by Captain K; 03-10-2021, 09:26 PM.
Originally posted by elf View PostAny recommendations for indexable boring bars for a 2" boring head? Minimum diameter holes will be .375" and 1.5" deep.
https://littlemachineshop.com/produc...ProductID=5436
Originally posted by mattthemuppet View Postwhy won't the SCLCR bars do a flat bottom - they can bore to the bottom of a hole on the lathe. Or did you mean that they'll leave a ridged bottom depending on the depth of cut?
You can overcome this using these bars on the lathe if need be by feeding back towards the center of the piece to clean up the ridges.
- Likes 1
Originally posted by oxford View Post
Yes they won’t leave a true flat bottom, DOC will determine how “jagged” the bottom of it looks. May or may not be a problem depending on what you are doing.
Be sure to check the tool shank diameter for a 2" boring head, some are 1/2" and some are 12mm. An 8mm indexable would start in 3/8" hole, but would need a sleeve for the head. The 1/2" or 12mm shank bars would be easy to fit to the boring head, and are cheap, so you could have a choice of lengths cut.
I have some small TCGT inserts, might have to make up some boring bars for the mill. One issue I've found with the 12mm bars is the size of hole you need to start the job, so having 8 and 10mm step down shanks would be useful.
