Fortune / Victor 2040 lathe - $1,000 (Kingston, MA)
What's not to like is that it is on the other side of the continent (not to mention the border), as is all to often the case! 🙄
Victor is a good machine. The 3" spindle bore is hard to come by on a lathe that size. I would jump on that one if I were closer. I already have a really good 14 x 40 anyway. It's a killer deal for someone.
How can this lathe, with a 10 hp motor only specify a 30A max branch circuit?
My Summit 14 with a 7.4 hp (5.5 kW) on a 30A breaker has an inrush of 93A when the speed selector is at 1800 rpm (and the lathe trips the breaker after 8 to 9 sec) - I'm on a static phase converter.
If it's a clutch type drive , it starts up easier..... a bit like bench testing a motor.
if it's a direct drive, it's more like starting your car up in gear.. even worse if you have a 600 lb piece in the chuck...
I did not consider the Victor in the link to have a clutch. My previous lathe - mid '60s Clausing had a clutch but I thought (quite possibly wrongly) that newer commercial lathes of the size as linked to, especially those that have a foot brake, were direct drive. I really wish my Summit were clutch operated instead of direct drive, I just did not expect, and hence did not research, to see if there were newer clutch operated lathes with a foot brake.
Wow....Lots of machine for that price. I'm wishing I could jump on it.
Looking at pictures of the machine in the ad, and looking at photos off the internet. Maybe it's old eyes, or camera angle, but the one in the ad looks like it has a much smaller spindle than the D1-8 listed in online specifications. Anyone else notice that? Maybe I need new glasses......
Yes- it looks more like a D1-4 or D1-6, but pretty hard to say just by the picture. Did anyone notice the Acu-rite DRO? One of the top brands of all time.
