Well, I've had it with guessing where my drilled holes decide to land themselves, despite doing everything else right. Decided to try and tackle making a new quill with a bit more OD surface area and a whole lot better fit. Just wondering what you guys think would be the best material to use. My first thought was 1144, then I saw some 4140 pre-hard, then cast iron in the size I needed....now I'm thoroughly stumped. It is for a small bench mill with a little over 3" of quill travel. Had originally planned to have the old one hard chromed and ground until I got to looking at the two flats milled along the gear rack that do nothing but remove contact area with the bore. Figured I'd have better luck making a new. Thoughts on material and why would be much appreciated. Thanks.
best material for making a quill
Yeah those flats are not going to be there for looks... They may well be clearance for something. You'd better investigate more closely before deciding to just eliminate them. The chrome and grind sounds like a much better idea to me. If you go ahead with this, before you finish the quill O.D. take a good rigid hone and hone the quill bore so it's round and straight.
Originally posted by old mart View Post..........You will have to find out whether the quill bore in the head is bellmouthed, ...........4357 2773 5647 3671 3645 0087 1276
"There's no pleasing these serpents"......Lewis Carroll
Originally posted by BCRider View PostPictures please. Not sure why a quill would have flats unless there's something against those flats that do SOMETHING!
No pics, but here's the profile of it:
Originally posted by A.K. Boomer View PostTo me chrome is almost a must --- it's hard to find something as tough and durable,
some mills have a pinch bolt to tighten the quill bore, is there anyway you could add one and form a elongated vertical slice? you would have to be sure about it as if you fail you turn it to scrap...
This does have a lock with a slit. I've tried snugging the slop out of it but noticed the tighter it's snugged, the sooner it stops retracting on its own which tells me the quill has a taper on it. Another reason for a new quill.
Originally posted by Doozer View PostDo you have an OD grinder and a hone or lap for the bore to fit it ?
-D
No OD grinder here, but access to one if it gets chromed.
As far as the bore goes, plan is to disassemble it and map out the ID with a tenth reading Mito bore gage. From there, if it's at least close to being round, I was going to make up a plug gage to proof out what will actually fit before executing.
And if it's egged out bad, well guess I'll then be asking how to get it honed out straight and round.
