Originally posted by Barefoot
View Post
best material for making a quill
Originally posted by Barefoot View Post
And if it's egged out bad, well guess I'll then be asking how to get it honed out straight and round.25 miles north of Buffalo NY, USA
Originally posted by Barefoot View Post... It is for a small bench mill with a little over 3" of quill travel. ....
This is going to be more work
than you mill is probably worth.
Just saying. It's either for love
or money, and this one sure ain't
for the money. Ask yourself, do
you love this mill that much ?
-D
DZER
Just doing a reality check here, but....
-D
Definitely not love...more of a necessity thing due to lack of space for the machine I want.
- Likes 1
Originally posted by nickel-city-fab View Post
I would make an aluminum or brass lap that is about 2x as long as the bore. Unless you have access to something like a Sunnen sizing hone (automotive shop...) if the lap is longer than the bore then you can avoid bell-mouthing.
Please elaborate. I've made crude laps out of wood dowels and strips of 320, but nothing on this scale. Would a lapping compound be used with this?
Please elaborate. I've made crude laps out of wood dowels and strips of 320, but nothing on this scale. Would a lapping compound be used with this?25 miles north of Buffalo NY, USA
I think that for this to come out an improvement, you will need to become familiar with both internal and external lapping. The suggestion of a internal lap 2x the length of the quill is a good start. Remember, there are, at least, 2 kinds of lapping - 1) where you embed (charge) the abrasive into the lap and 2) where you use non-embedding free abrasive. To my limited knowledge, either will get the job done. Internal laps usually have a mechanism to expand as the lapping proceeds. See: https://www.helicallap.com
Similarly, external laps are shorter than the work and also need a mechanism to shrink as the lapping proceeds.
This is going to be tedious precision fiddly work. Your skill and patience are going to determine the quality of the result. Good luck.
Ahh, it's embedded.... well that makes sense.
Now how is diameter of the lap determined for an egged bore?25 miles north of Buffalo NY, USA
I don't lap things very often, but when I do it needs to be right. I spread my abrasive out on a piece of plate glass, and shove the lap down into that as hard as I can, with my entire weight. This forces the grit into the aluminum or brass. I usually lap with kerosene or a very light oil. I have done hydraulic parts in this way with good luck.25 miles north of Buffalo NY, USA
A lap 2X the length of the quill sounds unwieldy even for a mini mill. Wouldn't 2X-3X the diameter be sufficient?
I successfully did a 2.06" bore with a lap ~1.5X the diameter, but I had to be very careful. I used a Duplex-style lap (see figure 16): http://www.modelenginenews.org/duplex/duplex_laps.htmlLocation: Northern WI
I'm wondering what kind of setup you'd be using to ensure the bore is aligned. I presume it would be set up on the carriage and fly cut using a boring bar held between centers. At least I think that's what I'd do to get the bore straight and remove bell-mouthing. Not sure that lapping would be the right operation here-I seldom do anything within the scope of logical reason and calculated cost/benefit, etc- I'm following my passion-
