Originally posted by skunkworks
View Post
Simple control of one stepper motor?
All you need for a simple test is a regular 8mm inductive sensor, a switch and a drill with a some kind of gear attached to the chuck. The switch is used to change direction and the sensor will generate the pulses as it detects the gear teeth as the drill rotates.
There are many ways to skin a catHelder Ferreira
Setubal, Portugal
- Likes 1
Originally posted by Mcgyver View Post
Question....when I control a stepper with say an Arduino, its clearly seems like its stepping. i.e. stepped motion not smooth. With a board like above that is PMW, does it behave differently, more like a smooth electric motor?
side note, a decade ago I was working on project with a weirdo genius and he had some stepper controllers that let you spin them at a few thousand RPM, silky smooth, never any hum or acoustics at any speed. They were expensive and not really commercially available. Apparently buddies buddy would sell these early stage versions to is friend, but it wasn't fully commercialized yet. The breakthrough irrc was mostly software around feedback and derivative controls. I know steppers with accurate positioning at 2500 rpm sounds fishy but I saw it and worked with them, just wondering if this had advanced at all or was commercially available.
Probably a very high micro step drive. The higher the micro step the close the motor is running on a true sine wave which means less harmonics. And they probably kick the PWM frequency beyond audio range. Parker makes some drives like this. They are not cheap. There are also variable reluctance motors which operate similar to steppers but don't use a permanent magnet rotor, they are very quiet.
Microstepping is for smoothness, not increasing resolution. Depending on the motor moving from one micro step to another may not even move the rotor, especially at the higher step modes. That why Vexta has the AlphaStep motors which use a feedback sensor that detects if the motor is not in position and command the drive to compensate. The closed loop mode only kicks in when it detects a position error unlike a servo which is full time.
- Likes 1
