Can anyone give a better explanation of how this works or is more fuel efficient other than four cylinders are not firing, other than what is described here "four of the eight cylinders is switched off and a solenoid system collapses the valve lifters to reduce the pumping losses and improve fuel efficiency."
OK, I get that, you shut the valves off basically........ So either your compressing the trapped air as the piston goes up or creating a vacuum as it moved down. Either way there is a drag.
Your turning half a dead engine.
Trucks have jake brakes, opens the exhaust valves and the enging breathes in and out of the exhaust. That creates quite a bit of drag as it slows the truck down.
How does the drag out weigh the fuel that is being saved?
To me, it more stuff to go wrong and working on today's motors are not fun.
https://gmauthority.com/blog/gm/gene...on-technology/
JL...........
JL...........
