What are these?
  • What are these?
    What are these? Something I inherited with some other machinist tools.
    Peter
    Grantham, New Hampshire
    They are things to make you go "Hmmmm..."
      Long broken taps made into punches?
        Parts from a portcullis repair kit.
        Regards, Marv
          Transfer punches? Can't explain the square ends.
            Practice work pieces from a grinder? Wild Guess due to differing mounts and lengths .
            S E Michigan
              Taps that broke in the CNC while the operator was sleeping.
              It's all mind over matter.
              If you don't mind, it don't matter.
                Test specimens for a very powerful pencil sharpener.
                  Stuff turned into other things through grinding, turning and milling which can be further turned into other stuff via various other processes.
                    If they were tungsten they could be tig electrodes ( biggest I’ve regularly used 1/4” sylvania green band), centres for a watchmakers or clockmakers “ turns” looks lathe ish but two opposing centre points, posh nails, tyre prongs, some kind of mini sabot round for a smith and Weston, splinter diggers, I give up though my immigration is now zooming along
                    mark
                      I would have gone with "broken taps made into punches", but I've never seen a tap with that much shank before it became threaded. Of course, perhaps that's how they broke - easier to wiggle.
                        I don't know what they are, but this gave me the idea to make a bunch of random stuff like this to fill a drawer of my toolbox, just to confuse who ever inherits it when I go.
                          Looks like punches made from pulley taps.
                          John b. SW Chicago burbs.
                            Do they happen to be valve guide bore sizes ? Did they come from an auto machinist or engine rebuilds ?
                              Looks like watch makers centers.
                              They would have to be small though. JR
