Need some machining help.
  • #16
    insuspect the ratchet would work without the vertical slope also.
    • #17
      A 45 degree end cutter, tilt the head 22.5 degrees, hold the work flat, cut with the Y axis and advance each serration with the Xaxis.
      • #18
        Originally posted by junkaddict View Post
        Forgive the 3rd grade art quality of my drawing. My smart ass son asked me if I was drawing an iguana.
        That cut me up pretty bad lol whether he knew it or not he's got a great sense of humor lol
        • #19
          This would probably be the easiest way to get what you need. Pretty easy to grind up a toolbit to the proper angle for use in a flycutter with the head tipped at an angle.
          • #20
            Originally posted by Jerrythepilot View Post
            Oops! Thanks Matt, I misread his intention.
            no worries!
            That seems obvious now looking at your nutcracker. I was way overthinking this. Tilt the head 45 degrees with a 45 degree cutter, and it still will cut a 45 degree notch. Thank you. And that is one hell of a nut cracker.
            lots of ways to skin a cat as they say That nutcracker was my Christmas present to my wife, she was very happy with it which is the main thing! Then she scored about 30b of pecans so we all worked in shifts to get through them. They tasted real nice
            • #21
              Perfect job for your mill, as long as you can nod the head to 90 degrees. Or for a horizontal.
              • #22
                And it worked.
                • #23
                  aw man, that looks fabulous, nice job!
                  • #24
                    Looks like you are making a planemaker's float or rasp.
                    West Sussex UK
                    • #25
                      Looks like it worked well, great job.
                      • #26
                        Good result, a lot of patience required, though.
                        • #27
                          So my hare brained idea here is to inset the rack as it were into a aluminum bar, and the opposing teeth into a aluminum slot piece. A tilt to lock under force mechanism almost like one of those bar clamps with the lightly serrated edges, but with actual engagement. Might work for the application I'm working on, might not, I guess I will find out.
                          • #28
                            Wow that's beautiful
