+1 for the "solid" tyre. Would never go back to pneumatic for a wheelbarrow. Life's too short to spend it mending punctures.
OT: wheelbarrow tire replacement
What I have done in the past to facilitate seating tire beads was to make up short pieces of 1 x 2 lumber a couple of inches longer than the rim width and wedge 4 of them into the tires. After a day or two I would take them out and the tire remained spread apart. Mind you, this only works if you have the time and can preplan things.
Many, many years ago I got tired of having to air up my wheelbarrow's tire every time I infrequently needed to use it so one day I bought one of these solid rubber wheel assemblies and it was well worth it. That's hard rubber, too...not the foam type. My barrow is just a gardener type one with a smaller wheel and I rarely have need of it but at least now I don't have to fool around airing it up every time I do need it.
The tire shop I took a lawn tractor tire to for mounting a few years ago had a portable air tank with a shop made nozzle thing and a ball valve as a safer alternative to the lighter-fluid-and-match method. Might not be worth building one for home use but if you are in the business and don't want to burn your shop down...Tom - Spotsylvania, VA
Originally posted by flathead4 View PostThe tire shop I took a lawn tractor tire to for mounting a few years ago had a portable air tank with a shop made nozzle thing and a ball valve as a safer alternative to the lighter-fluid-and-match method. Might not be worth building one for home use but if you are in the business and don't want to burn your shop down...
https://www.ebay.com/itm/10-Gallon-A...EAAOSwojRgSD4W
Originally posted by Michael Edwards View Post
Originally posted by tom_d View Post
Those tanks work. Sometimes. I'll give it two tries and then it's the last resort option with the starting fluid and a match. When using the air tank method be sure to use some hearing protection! With either method put a self holding air chuck on the stem first so there is air inflating the tire as soon as the bead seats enough to hold air.
I put tubes in them. Problem solved.
JL...............
