I was given some tapered brass plugs used in refrigeration to plug defective lines .
I am going to make a hammer for light gunsmithing chores.
Should the handle be in the center or at the balance point?
Since the plug is only about 2” long the center and balance point are only about 3/16” from each other and may not be noticeable while using the hammer.
