I was looking for some red layout fluid, going to try brush on this time, and saw that Dykem also has staining colors. The specs look to be about the same for each with the exception of the staining colors which are available in several colors. The layout fluid comes in the traditional red & blue. Sharpie markers are OK but the ink tends to rub off too easy.
The staining fluid looks to be more for permanent marking of parts and leaves a thicker film vs temp. for layout and machining.
Anyone have any experience with the staining fluid ?
JL..............
JL..............
