Figured it out, operator error. I realize that I might possibly be an idiot who cannot read, understand, and follow simple directions. Index issue(hmm, I think that was mentioned more than once) When aligning the drill bit, as seen in the first picture, the depth is set, bit locked in the chuck fingers, then the rotational lock is freed. The pawl blocks are then squeezed together, and the chuck rotated until the bit locks on the steps. I was letting the pawl blocks come together, and push the chuck back. I was doing this without even realizing it, because it is the natural motion where things want to rest. This allows the chuck to rotate considerably more, locking the bit a good 20 degrees or more out of the correct positioning. Reading the M2 manual, it mentions holding the chuck forward so the bit tip stays in contact with the end plate, and not letting the chuck walk back. I thought, it can't be that simple, well, it was. I noticed, starting with the M3, this rotational lock was removed from the chuck, and an alignment line put on to align with the with the scale on the fixture, with the locking of the drill bit in the chuck satisfying both depth and relief requirements. I wonder if this is why it was changed? Or maybe I am just trying to make myself feel better.
