Diamond in the rough? SB lathe $800 Chelmsford MA
This thread is now the poster child for why reproducing the pics in the thread is important. Most every comment is now worthless, since the CL advert is gone.
- Likes 2
Originally posted by tom_d View PostQuite the machine for the money. Tool post is a bit of a hokey design, but it's workable. Nice that there's a four jaw chuck, and the three jaw has reversible hard jaws. That looks like an original South Bend steady rest. Worth a few bucks right there.
I just noticed, it looks like there's a genuine thread cutting stop clamped on to the carriage. Don't see those around that often these days.
- Likes 1
Originally posted by alanganes View Post
I don't think that is a VFD, but I am pretty sure that is a variable speed DC drive. Every bit as good as a VFD if it's done reasonably well. I think it says "Browning" on the front. I don't need a lathe, but I agree, that could be a nice deal for someone.
My south bend too was listed as total bed length.. so 60 inch id probably 40 ish between centers.l
Originally posted by Bob Engelhardt View Posthttps://boston.craigslist.org/nwb/tl...295260663.html
It says "16x60", but that doesn't look like 60" to me. Only a single stage QCGB with 8-10 speeds/pitches - I suppose that means you can re-configure the open gears for other feeds (?). Is that a VFD on the wall?
I had a single-tumbler Sheldon lathe, sometimes wish I had never sold it. These old cone head lathes run very quietly, and are dead nuts simple to tear down and clean up. About the only deal killer would be a bed so worn that it needs resurfacing. It's probably in the 2500 lb range, which tends to keep some of the home shop guys away, because it can't be just picked up and horked into place by a couple of guys. There are countless online resources that support SB lathes, used parts are abundant, or easily made. It's about as simple as a lathe gets. No brainer, imo. 3 and 4 jaw chucks, and the steady. Rent a tilt-bed trailer, roll it out and winch it on. I doubt it will last long.
That makes a lot more sense than what I was thinking. Just as convenient, almost, as 2-tumbler.
Originally posted by MrWhoopee View PostGood price!
South Bend specified bed length instead of center to center distance, which includes the portion under the headstock. My Heavy 10L is a a 10x48 (48" bed), which gives me a little over 24" c-to-c.
Somebody is going to snap this machine up for a real bargain. Wonder why the ad is still up after two days? That machine is not exactly an easy one to move, pretty heavy, not a throw into the back of the SUV deal. Not your typical home shop down the stairs to the basement move.
Good price!
Originally posted by mattthemuppet View Post... That's a full norton gear box, just an older version with a single tumbler instead of 2 like the "newer" South Bends. There are 2 ratios from a sliding gear on the banjo, 3 ranges from the lever on the top and then the different ratios selected with the tumbler lever.
Originally posted by OaklandGB View PostThe only other perspective in the CL photo might be the concrete block wall. Those are likely standard 16" concrete blocks.
I dunno....maybe just the perspective of the photo. I found a SB 16x60 photo in roughly the same position as the CL listing. Just the distance between the left machine foot and the right side legs, seems like the CL machine is about 1/3 the length of the 60 inch model.
Again, still a good deal.
That is one heck of a deal at that price. We used to have a single-tumbler machine like that at work, actual between centers was closer to 40".
