Wanted to add a 12k winch to a trailer and hope to finish by the end of this year. I had to modify the existing tool box lid to keep it as low as possible when open so the winch mount would not be so high. I cut the stock lid in two lengthwise and welded on some hinges to make it open like a bi-fold. Welded in some channel and made a mount for the winch. Bent some diamond plate and milled the diamonds off to conform to the shape of the winch hawse so it would sit flat. I am installing an air compressor that will work off the winch battery. I had installed air spring helpers on my truck so the air compressor will work for that and other things. The project is at the point where if I really need the winch I can bolt it in and use it but the whole project is a long way from being finished.
This is what a stock tool box lid looked like.
Cut the tool box lid
This is with the hinges welded on and open. The hinges are hidden when closed.
And with the lid closed
Bent up bracket for winch and machined winch rope opening
