It would be a real kicker if it all boiled down to somebody having a brain fart.
Container Ship Stuck In The Suez Canal OT
The visibility from the bridge on that ship is truly terrible when she is loaded as she is to the max. Anything dead ahead that's closer to the bow than damn near a mile is simply invisible.
And although the radar scanner is above the bridge, the slightly better angle that elevation gives it will not make much difference.
Letting something the size of that into a narrow canal is simply insane.
Originally posted by Mike Burch View PostLetting something the size of that into a narrow canal is simply insane.And considering dozens go through every day without problems, I'd see it the same way.
Lynn (Huntsville, AL)
If it were much wider, it could not have jammed across the canal. It might have swung around, but would not have ended up jammed across, only one end t a time could impact the shoreline of the canal.
If the canal were narrower, it also would not jam the same way, it would not be able to get stuck crosswise, the angle would be more acute. That probably would not let it get stuck so thoroughly.2801 3147 6749 8779 4900 4900 4900
It's just a box of rain, I don't know who put it there.
Originally posted by old mart View PostWhen you look at the canal profile, it is obvious that the ship would have grounded even if the waterway was twice as wide. The slope of the sides is very gentle.
But NOT at both ends at once. Grounding at bow only may or may not be able to be remedied by reversing during high tide, no further ado.
And if it were narrower, it likely would not have the wide flats at each side. The channel for a ship that big is much narrower than it appears, since the 15m draft is more than the side depth appears to be in the cross-sections I have seen. How accurate those are is open to question.2801 3147 6749 8779 4900 4900 4900
It was just the wrong width at least in that section, like many things - "the perfect storm"
Like JT stated if wider then the tail would have just pivoted around and not got stuck --- all that weight tried to keep going and it wanted to "swap ends" this too created the horrible situation of the entire ship going "sway back" ------ if just the nose stuck and was raised the tail would have been free to sink in a little more,,,
I think the ship was in a slight side drift when the nose caught making the situation even worse so the tail tried to keep going and just plowed the stern into the opposite bank as well .
Edit; I wonder what the torsional stress was like on that beast, with one side of the bow catching more land and the opposite side of the stern doing the same it too had to be immense...Last edited by A.K. Boomer; 03-30-2021, 03:12 PM.
One question would be why they keep making these ships larger. Maybe the canal fees are structured on a flat rate per ship, but it really should be based more on the size and weight of the ship and its cargo. It might be argued that two ships half the size would require two separate crews, but I doubt that is a huge expense.http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
Originally posted by PStechPaul View PostOne question would be why they keep making these ships larger. Maybe the canal fees are structured on a flat rate per ship, but it really should be based more on the size and weight of the ship and its cargo. It might be argued that two ships half the size would require two separate crews, but I doubt that is a huge expense.
JL.............
- 1 like
The canal is too wide. If it was narrower, the ship could not have slewed around enough for the bow to dig in- on the other hand it isn't wide enough. If it was wider, the stern would have just slewed around and the ship would have been looking the other way- let it go around again and off you go- just like us with our cars back in the day doing 360s.
Looking at it another way, perhaps the ships are the wrong shape- they should be round. No bow to dig in, no stern to catch. Make a convoy out of them- make them two miles long, doesn't matter. You can still go around corners, and if one titanics and sinks you can just let it go- you don't have to lose the whole convoy.
Whoo hoo- my mind is razor sharp today
