I purchased an inexpensive, three draw cabinet on the web because it was a perfect fit for a hole under one end of my work bench. I fully expected it to need some work in order to be useful and I am in the process of doing that with some stiffening on the bottoms of the drawers. It will still need to have a weight limit but I can live with that.
When the cabinet arrived, the box was partially crushed and the thin gauge, sheet metal (steel) cabinet was damaged on the rear corner and the bottom drawer's bottom was bent upwards. So Amazon replaced it and told me that if I did not get any instructions for sending the damaged one back, I could do what I wanted with it. It has been over three weeks and I want to see if I can do some sheet metal work to make it usable in some other location. But I can not figure out how to get the drawers out. They seem to have an integrated slide but they pull out about 3/4s of their depth and just stop there. I have stuck my fingers in as far as I can, probably further than is safe but can not find any kind of a release mechanism. I am wondering if anyone has run into any like this and figured out how to release the stop so the drawers can be removed? Any hints or suggestions would be appreciated.
That is with the drawer opened as far as it will go. There is an "L" shaped slot in both sides which is near the front frame when it is extended like this. But I can not see of feel anything behind it. It is visible in the photo on the left side of the drawer. It must have some function. But what?
If I can't get the drawers out so I can work on them, I can try some auto bodywork tricks but it will be easier if I have access to the inside. All three drawers work so I am not going to just toss it out.
