Good morning everyone!
I know that the VFD thing has been just about run into the ground but I need some help from the gurus around here and the search function wasn't turning up quite what I was looking for.
I'm working on running a new power line in my shop for my lathe. At current I will be running it on the original 110v 1/3hp motor. In the future I intend to use a 1.5hp 3ph motor driven by a VFD. To that end, I want to run the wire for both the 110 circuit and the 220 circuit for the VFD now to make future me happier. To help me decide what type of wire to run I decided that I needed to select my VFD now. Which brings me to my questions.
Will the VFD at this link be sufficient to run a 3ph motor with the nameplate data in the photo?
The drive is supposed to be rated for 7A on the output. I've read that the drive needs to be sized with a bit of extra head space in the current capacity but I've not seen a rule of thumb about how much over.
Now for a question about the input side from my panel. I know that the breaker needs to be sized to protect the input, how do I know how much it will draw? I've not seen this in the data for any drive I've looked at. Can I reasonably assume that the input current will not exceed the output current? If that is the case, is a 220V 15A breaker too large? Would I need to add some sort of fuse or specialty breaker between the panel and the VFD?
VFD users, do any of you have VFDs equipped with dynamic braking? Is that something that is nice to have but not essential? I will be using this on a belt driven Logan model 200, would the braking just cause the flat belt to slip?
One final question for now. Should I be looking for a constant torque drive, a variable torque drive, or one that supports both?
I think that's all I have for now.
Thanks in advance!
Jerrod
Thanks in advance!
Jerrod
