Two newbie tips
  • Two newbie tips
    A couple of tips for the newbie came to mind today they are really simple and most of you probably already use these methods but I thought maybe some of the newer blokes might find them handy
    Screwdriver slots- to refurbish or form a screwdriver slot, put two blades in the hacksaw and saw away.
    Stripped internal threads- I have used this on chainsaws where the bar studs have pulled out of the saw body, all I do is find a bolt or piece of threaded rod a bit bigger than the original thread size, tap the original hole to suit this and loctite a piece in then drill and tap back to the original size, I have also made these inserts on the lathe and put a screw slot in them to fit them. On the chainsaw I used a 1/2" whitworth bolt and tapped the internal M8.
    Will
    Wow, two more for the tips book 3.
      One more tip
      Leave the chuck key in the chuck on the lathe - guaranteed to give any visitors from 'Health & Safety' an instant heart attack.
      What you say & what people hear is not always the same thing.
      www.remark.me.uk
