Boy this car is finicky
So iv made pretty good progress with my preheat system but am waiting on my preheat hose which no auto store could get the one I wanted but guess what? home depot could so it should be here next couple days, just in time for the warmer weather lol
Anyways --- getting to know this thing a little better and since it's just a 1 liter im not only looking for efficiency gains but also an extra pony or two if it does not effect anything,
so while doing this other stuff I seen the throttle body and could not help but notice the two large button head screws holding the plate in it's place --- right in the smallest section of the bore --- it's a factor --------- if there's anyplace where power is being lost always think about intake restrictions, they are so critical as it's the single biggest gain area if they are impeding flow in any way...
Pic is plate wide open;
So --- I set out to remove said screws - easier said then done as the other side is "stamped" on the threads to prevent this (so they do not fall in the engine) in fact you can see this in the first pic, trick is to just drill the heads off and they will "drill spin" in a ways and then you can get some needle nose on them and get them out that side, Do one at a time so the plate never shifts - always keep one tight,,, after that a carbide countersink and then grind to size and install (WITH LOCTITE!!!) some flat countersink allen heads...
WOW what a diff --- this car redlines at 6,000 rpm's but would start to fall on it's face at about 5,500 --- and now - even a mile high she pulls to 6 and pulls up the entire way noticeably better... any little gains in this area amount to being compounded because additional air flow is increased power...
The thing is - is between doing this and cleaning the throttle body from surface carbon it tripped up my mixture into going too lean, It seams to have taken a bunch of restarts for the computer to re-calibrate things - but now all is good and back to normal....
