Unless you're measuring fuel economy with stand-alone equipment in a lab there's no way to get an accurate fuel economy number. The built-in systems cars use is a guesstimate at best and in any case there are too many factors on the street to get a solid, repeatable, number.
The only reason intake preheating was popular in the carbureted era was to get the fuel to evaporate (instead of puddle) in a cold intake manifold. There's no need to preheat intake air on a fuel-injected engine (ok, some diesels do as a starting aid).
In any event, fuel sprayed with an injector isn't in the air long enough to pick up any meaningful heat that would affect evaporation or atomization.
