What oil are you 9x19 - 9x20 lathe owners using in the spindle bearings and where do you purchase from? The book says ISO 32, but my local places do not carry.
Oil for 9x19 Spindle
ISO32 is a very common hydraulic oil. Many spindles and machines specify a hydraulic oil which is a non detergent oil. My cnc lathe uses that for its spindle with a tank/pump and recirculating system. The term "hydraulic oil" throws people off thinking it is for use on hydraulics only, not true, its very commonly used in lots of different machinery with bearings and general purpose lubrication needs along with being non detergent. Place I worked years ago had many very large printing presses, they all used ISO32 hydraulic oil.
As for a source, most auto supplies, tractor supply, and lots more carry it. Once you look for ISO32 hydraulic oil you will find it all over.
- Likes 1
Sparky completely anwsered that, very well. In my case I was dumb enough to mail-order a quart of Mobil Velocite #10 spindle oil.... which just happens to be a non-detergent ISO32 oil. A quart will last me a lifetime, though. Lesson learned, I could have just walked down the street to the auto parts store.25 miles north of Buffalo NY, USA
Velocite #10 is an ISO 22 viscosity so is a little thinner, but I agree spindle oil and hydraulic are interchangeable if the same iso....at least with the spindles and speeds our machines have. Both are just fairly pure mineral oil with some anti oxidants and rust inhibitors. I recently bought a gallon is Velocite #6, the right stuff for watch makers lathes....and man, they sure are proud of it! Could find hydraulic oil light enough (iso 10)in Toronto Ontario - where are you?
Originally posted by Sparky_NY View PostISO32 is a very common hydraulic oil. Many spindles and machines specify a hydraulic oil which is a non detergent oil. My cnc lathe uses that for its spindle with a tank/pump and recirculating system. The term "hydraulic oil" throws people off thinking it is for use on hydraulics only, not true, its very commonly used in lots of different machinery with bearings and general purpose lubrication needs along with being non detergent. Place I worked years ago had many very large printing presses, they all used ISO32 hydraulic oil.
- Likes 1
Quite a bit of hydraulic oil does not specify the viscosity.... the "hydraulic jack oil" at Autozone or O-Reilly's does not, for instance. However, it is very thin and sloshes like water. Appears to be at least "SAE 10", but of course with no actual spec, you are on your own.4357 2773 5647 3671 3645 0087 1276
"There's no pleasing these serpents"......Lewis Carroll
Originally posted by tom_d View Post
Hydraulic oil for John Deere tractors is sold under their brand name Hy-Gard, which has a ISO spec between 46-68. Their Low-Viscocity Hy-Gard is ISO 32. It has been in use for decades in tractors with a common sump for both hydraulic functions and transmission lubrication. There are some additives for anti-wear, and to help make it compatible with the materials used on wet clutches and brakes. Works great on lathe spindles too.
Retired - Journeyman Refrigeration Pipefitter - Master Electrician
- Likes 1
Originally posted by Galaxie View Post
Use the Spindle Oil Constant 3.5555
9" lathe X 3.555 = 31.995, use 32 oil
12" lathe X 3.555 = 42.66, use 42 oil
OK, I'll bite. Where is that from? Or did you just make it up?
Originally posted by Mcgyver View PostI would have a thought the John Deere oil would be more expensive than the Velocite
Originally posted by nickel-city-fab View Post
I've been meaning to try their corn head grease in bed. It's the only JD product I can afford (barely)
