That inertia thing was crazy.... Although there is a point when you reverse it through the backlash in the adjustment, maybe.... I pretty much took it as the larger wheel being easier to adjust simply through better leverage.
Some things the guy says...... well, some things ANYONE says, may be "off". I was interested to see if what he says is in any way in agreement with others who are knowledgeable and skilled.
I know some custom woodworking folks. The best of the lot is a guy who makes very nice commissioned "art" furniture, who is very good, sensible and grounded. He could probably do better work with a Bowie style knife that some folks with a shop full of the best tools.
Some of the others are pretty much "you can't do anything with that tool, you need an XYZ brand or you will just fail" (I've seen that here as well concerning metalworking, although not so much). I'm not generally in favor of that view, but since I am not much of a woodworker, I really don't know for sure.
If Rex were FOS, I might recognize it, but then maybe not since I don't have the experience of various different tools, and do relatively little woodworking.
I will say that I used his plane setup information on the worst POS I have in the shop (it's a really crappy block plane), and I got it to actually work rather well, considering what it is. So "planely" he knows a thing or two and can communicate what he knows..
It's that sort of info I found interesting. Found I did not know s**t about setting up and using a plane.
