Unidentified Lathe Tool
  • Unidentified Lathe Tool
    Hi,
    I got this with some other lathe tools but after searching still don't know what it is or how I use it. Any ideas?
    Trepanning cutter, missing the arm and cutting bit maybe? This, but on a Morse taper: https://www.kbctools.com/itemdetail/1-805-55
    Ian
    All of the gear, no idea...
      What is the part in your fingers? And does it slide or is it held? I think there's a big clue in that.
      If it is a trepanning tool I'm thinking it would only be good for smaller holes. Otherwise the high torque would tend to spin or pull the taper out of the socket. Morse tapers only hold well when being pushed firmly into place as with drilling. Or pulled with a drawbar.
      Chilliwack BC, Canada
        Looks like a circle cutter with the arm missing.. what size is the part the fingers are holding? Is it removeable ?
        tried to post this earlier, did not go thru.
        i have a deluxe trepanner, it has a square part that sides thru, M3 , good for about 4 inch dis holes , itz all in the tool grinding.
          I vote for some kind of circle cutter as suggested by 754. .
          S E Michigan
            The end has a pin in it. There is a grub screw to hold this (although at the moment it does not slide freely anyway, I'm sure it would with some persuasion)
ID:	1937437 Click image for larger version
ID:	1937438 Click image for larger version
              Yep, circle cutter, trepanning tool - basically the same thing. The part of the pin sticking downwards keeps the work centred under the tool, and the stub end sticking into the hole acts as a key to stop the circular cross section arm from rotating about its own axis. You just need to make / find an arm and cutting bit.
              Probably handy for cutting holes through thin material, gasket making etc - not heavy cutting.
              Ian
                I’m also with treppaning but could be a clock holder, I had one with a long arm, morse taper for centering on a HBM or mill, very handy it was too, bung in spindle, sweep bore, move table the wrong way, repeat
                mark
                  Well if anything you did post up some great photos. Thanks. JR
                    Hard to say exactly what it is. Look at the last picture in post #5. Note the scribed lines at 90 degrees on the end. That implies to me more of a homemade tool using the lines to align for machining cross holes. A factory made tool with a specific purpose likely would not need the marking to build. Also, the large cross hole does not appear to be precision finished, kind of ragged looking interior finish.
