I just can't get over the power of a simple laser level. Unfortunately, it's making me greedy for even more. It's nice to know how not flat my surface is, but where is it not flat? And how perpendicular is it to that other surface over there? Is it parallel to that one as well? Basically, can I measure everything there is to know about my machine tool, whether to adjust it, rebuild it, or create it from scratch?
So, the Internet is a dangerous place. I went looking and looking, and I did find a couple of interesting hits. I'm not done searching, but I did think I would share some information. As nearly as I can tell, the key to using lasers for metrology (hey, that's a big new word, eh?) is something called a PSD, which stands for "Position Sensitive Detector". This little gomer is designed to tell us, with extreme accuracy, exactly where the dead center of a laser beam is hitting the sensor. Nifty, eh?
Now using said device, we can do all manner of machine tool alignment and checkout. I like Hamar Laser's description for machine tools the best:
http://www.hamarlaser.com/howitworks...ng_Centers.htm
As near as I can fathom, once you have the PSD to tell what the laser is doing, the rest is gravy, and it seems like you can use a cheap laser level for this purpose. My next question was, "Where the heck am I going to get a cheap PSD?" On this one, the jury is still out. Colleges are fiddling with them in student experiments:
http://physerver.hamilton.edu/people...deflection.pdf
How about measuring the deflection of the laser as a sound wave passes over it in air? Obviously these things are pretty sensitive! A little more research turned up this article about how to build one:
http://www.circuitcellar.com/library/print/0303/5.htm
They use it to map a surface plate to 0.0001", which sounds right up our alley. In fact, that then led me to look to the end of that article and find out the gadget they show how to build is available commercially:
http://www.aculux.com/Alignment_pricing.htm
Not exactly cheap at $750, but it is still a pretty amazing deal compared to what real CNC laser alignment tools cost.
There's probably more and better to be had from deeper Google dives by better minds than I, but this definitely whetted my appetite.
Best,
BW
Best,
BW
