so is the reason for all this to make the taps fit your tapping guide? make a suitable tip for it. i have.
5C Collets For Tap Shanks
just be aware that all claims of runout are bogus. there seems to be no standard of measurement. it makes a difference if you take a reading at the collet or 10xdiameter out (like for drill chucks). even my regofix ultra precision collets (5ยต advertised) dont live up to it, although in this range measurement are becomming questionable (or take a lot of extreme care).
Originally posted by masheenest View PostA "Polychoke" tap sharpening fixture comes with collets to fit tap shanks.
OP should buy an ER collet chuck with an R8 shank. Very handy in the mill as well.
Originally posted by Illinoyance View Post
Unfortunately mine came with no collets. I bought a 5C to ER32 adapter. I can hold any size tap shank up to 20mm.
JL..............
to not over complicate or spend a fortune....why not just make a sleeve? It only has to withstand grinding forces. Turn the OD to whatever, ID to fit the tap all without disturbing the work. part off and saw it in half. done.Last edited by Mcgyver; 04-09-2021, 06:13 PM.in Toronto Ontario - where are you?
