Hi all. I've got this part I designed for my senior design project. My plan was to weld it all up and then linebore it afterwards to solve any potential warping issues and make it overall easier. It doesn't have to be perfect, there are just splined axles running through into a differential, it can tolerate slight misalignment but I'd prefer it to be close.
So here is the parts. Material is 6061 T6 Aluminum
Here is the bore they need
1.75" by the way for a 7610DLG bearing. I'd also like to face a small area for the snap ring incase it wasn't welded totally straight.
and here is the assembled view basically:
So, when I planned it, I figured I would just chuck it up and bore it with the 4 jaw. Well, that is sort of problematic, as I didn't fully comprehend how long they were until they were done. My longest two big boring bars are both 12". So that isn't really enough in the CXA holder. I could make a longer bar, but then I'd almost assume make it for a CA holder, which I now have a post for, but no holder, so I'd have to make or buy that too...
So, here are the options I can see.
But, what I'd like to know is:
So thanks all, try to keep it fun.
- Conventionally bore in in the Lagun 1440 in a 4 jaw.
- Conventionally bore in in the Sidney 18.5x54 in a 4 jaw.
- Line bore it in the Lagun with a true lineboring setup.
- Line bore it in my camelback drill press.
- Line bore it some other way with plate-mount spherical bearings mounted directly to the pieces themselves.
- Bore it in the Bridgeport with a boring head on one side only, flip it and index in a jig, hope the second side is right.
- Tilt the Bport head 90 degrees and linebore with it on it's side using the table feed?
- Drive up to NC and beg Doozer to help out? :P
- The Lagun doesn't handle extreme overhang well. It has a short headstock side of the saddle, and the compound almost already leaves you overhanging. Except for very light cuts, that is asking to lift the tailstock end of the saddle. It's undergibs are tight though. Secondly, I want this held securely, and the 10" 4 jaw won't cut it gripping over 7.5" with the jaws set for OD work. I also want a packing block to spread the load on the 1.75" tube. So that means the 12" chuck. But now, with 7.5", plus probably 1" of packing block, plus 4" of jaws, that is 16.5" of swing required. So I'd have to pull the gap. I'd rather not.
- The Sidney would handle it fine. Except the cross-slide is whopped out and it doesn't like long bores. The longest I've done was 8". It handed it fine, but I couldn't hit any accurate dimensions. That may be fine if dad's adjustable reamer set goes up to 1.75". I think it may. I could also do a quick fix on the cross-slide with external gib lock screws, something I've been meaning to do for a while. I'd still probably need to ream it or glue the bearings in.
- Some of the Laguns came with a slotted cross-slide. That would be perfect here. We don't have one. So I could rig something up to go in place of the compound. We have a big 1" thick cast iron angle plate which is about 7x9". That would do it. I'd have to drill some holes in it for the compound bolts, but that isn't the end of the world. I'd also have to make a line boring bar. I don't think we have an MT7 to MT4 adapter, but I could buy one or just make a chucking version. At any rate, a lot of work, but probably the best option. (The Sidney is not a good option due to the ways being bananna shaped. This isn't an issue for turning as it only affects the tool height, but for line-boring it would cut a matching banana.)
- Another decent option. The two cons are that I don't have a setup built (so MT4 boring bar again, bearing on the table) and it only has 7" or so of quill travel, and no sliding head. So I'd have to raise the table mid bore. It's all doable, but dang that would be a lot of work too.
- I'm not sure that this option saves me any time over the others.
- Probably would work given the accuracy requirements. T'would be quick, I'm already tooled up. I'm not sure if I have the vertical height though. Un-rised B-ports have what, 18" between the spindle and table? I could hang it off the front of the table if not but.. eh.
- Dunno, never tried that. I'd have to build some tooling of course.
- Assuming you have the capabilities, how would you do this in your shop?
- Given the list of possibilities I have mentioned (or something I have overlooked) how would you do it with the machines that I have listed?
