Is it possible to machine a Oval Shaft
  • Tundra Twin Track
    Originally posted by gellfex View Post
    No, I'm still talking about pouring resin into the section you're concerned about. I'm just saying it needs no tensile strength from fiber at all, I think the issue is all resisting collapse, or compression. The long axis is not the one that will collapse!
    I got it what your saying ,will deal with it before the new season late in the fall.
    Thanks again for everyone’s different ideas.
  • reggie_obe
    I think what you are attempting could be done with a lathe relieving attachment. Maybe build the Eureka.
  • oxford
    I do not see any oval and I don't even see a lathe.
    Did you mix up your photos?
    Paul, I see the correct pics and yes there is no lathe present.
    Its hard to photograph, you can barely tell from the side views of what going on.
    The one view of the top you can see it and look below the square stock that is welded on and you can see the “oval” profile of the big end.
    I made this quite a few years ago and didn’t take any pictures of doing it. It is a bracelet mandrel for jewelry making. I made it for the wife for Christmas one year.
    It was made out of 304 stainless, it took forever, sucked doing it with the interrupted cuts, and my lathe was not happy about doing it.
    I’d have to measure to be sure but it’s around 12” long on the oval part and probably started with 3” OD stock.
  • old mart
    If I was going to produce the profile, I would push it through profiled rollers which can be adjusted for their spacing. The original profile would have been easy to make, if it looked ok, then it was. To copy an existing profile, some experimentation would be necessary to get a match. Any swaging would be easer to do while the tube was still round section. The swaged end would need to be profiled in a separate operation.
  • gellfex
    Originally posted by Tundra Twin Track View Post
    I assume your talking about a adding a flat brace on the longest portion of the Oval,my thought was to cut a Aluminium Flat bar 6-7” long stepped down for smaller portion and slide down from large end.
  • Tundra Twin Track
    I've not taken an avalanche class, but aren't they powder? 'concrete snow' doesn't seem like stuff that will avalanche very well!
    When I say concrete snow I’m referring to the deposit of snow after a Avalanche has taken place.There is numerous types,I’ve seen hard blocks the size of Volkswagen’s the are very hard and other’s that are Loose Snow which can be Shovelled.All Avalanches firm up after the snow stops moving,some quicker than others.
    Was contemplating the reinforcing issue while puttering. Seems to me all you need is compression blocking inside to keep the tube from collapse failure. The tube will not fail from extension ie tensile strength failure. It would fail from the narrow diameter ends of the ellipse bulging at the strain focal point and one side of the major diameter folding or collapsing inward. All you need is cast blocking to prevent that, no glass or such needed.
  • elf
    I could do it for you on my rose engine as long as it's only 6" long
  • oxford
    Originally posted by tmc_31 View Post
    Ok guys, since this a free thinking exercise, how about this. Mount your stock in a 4 jaw, offset the stock by an appropriate amount. Mount a 4 jaw revolving tailstock chuck, offset work a like amount and direction as in the headstock chuck. Turn until you get the profile you want on one side then rotate the work 180 degrees, turn until you get a matching profile on the other side.
    Wouldn’t this be the same as turning between offset centers?
  • gellfex
  • tmc_31
  • gellfex
  • Tundra Twin Track
    If you're just reinforcing that section do it with fiber and resin by blocking the tube and pouring it in. It's fast, easy and effective. The weight savings from trying to keep it hollow is not worth the effort, its a couple of ounces and you're not backpacking it! Did you have one fail at that spot?
    The resin & fibre route may be the best as others have mentioned as well.Been using this setup for 8 yrs with no issues but have read that some fail digging in concrete snow.Some Instructors test these shovels by extending handle full length laying them face down on frozen ground then stand on it with one foot wearing ski boots and stomp with other foot to make them fail.I don’t really agree with that as most fail,I’m sure most live recovers are not concrete hard snow.
  • gellfex
  • Black Forest
    Are you wanting to make it out of solid material? Aluminum I would guess. Between the arrows there is a reduction in the cross section. Is the bigger side round or also oval shaped? Is it your plan to slide the reinforcement piece down the bigger long end? Me, I would just go over to the belt grinder and freehand the shape. I would make two different "plugs" out of wood to the exact size you need. Then I would screw one plug to one end of my material and the other plug to the other end of the material and then use the plugs for reference while grinding on the belt grinder. With patience and due diligence I could get it to fit nearly perfectly. But I have a lot of experience on a belt grinder. I mean lots and lots.
  • dian
    simply do a carbon/epoxy reinforcement (blow up a piece of bicycle tube inside).
