Hello folks, Long time no see.
My current project is making a tube for a telescope - 14" diameter and 45" long. Despite being around several manufacturers, nobody with a > 4ft roller wants to help me out. (Or they will, for an exorbitant price). My workplace has a little 2 foot roller, so I might have to make the thing in two pieces and attach them somehow. I have a set of end caps that need to fit on both ends, so the diameter has to be exactly right. So anyway, I have a bunch of questions:
- If the roller is rated for "16 gauge", what happens if I try to bend 14 ga 6061 Alu in it? I'll either use 14 or 16 ga.
- If I go the welding route, I will need them to both do a seam weld where the edges meet up, and also to stack the two cylinders on top of each other and seam weld that too. Oh, and weld in such a way so as not to mess up the heat treatment or warp the aluminum. Can this be easily done via MIG welding, or is it something that is difficult and expensive?
- If I go the route of using screws and nuts (not rivets because they seem too permanent) what's the common way to join the two pieces together? One way is to make both pieces as cones with a very very shallow taper so one fits inside the other. Another way is to butt the ends together and have another strip of metal underneath, then a double row of screws to join them. I don't know how to make an '"offset bend" on the end of a cylinder so that one just slips a fixed distance inside the other.
- Speaking of offset bends, is there a way to make one along the straight edge of the rolled cylinder so that the two sides overlap nicely? The only other tools I have access to are a sheet metal bender - the kind where you clamp the workpiece and the front lip lifts up, and a hand powered "brake" (I think that's what it's called) which has the v-shaped blocks that press down into a V groove.
