My set of shop blocks has suffered from neglect while my shop was in storage. I would like to restore them as best as I can. And yes, at some point I will probably just purchase a new set, but I have other, higher priorities.
What I see on many of the blocks, even on some that have never even been removed from the original, factory protective wrap, is a discoloration on the faces. I have tried several, non abrasive ways of cleaning them with mixed results. I can remove that discoloration from them, but it takes a lot of work and that means a lot of time for the entire set. Frankly, more time than the set is worth.
I have seen ads for stones that are intended to be used on Jo blocks. These stones seem to cost as much as my set of shop grade blocks originally cost. Perhaps I should just break down and get one. But I also have a pair of ground, flat stones.
The ground, flat stones, when properly used will not produce any measurable differences, even down to the tenths range. But the Jo blocks are supplied with actual sizes down to the millionth of an inch. So I am wondering if there is any difference between the ground, flat stones that I have and the Jo block stones sold for that use. Would, perhaps, the ground, flat stones produce a surface finish that would prevent wringing?
