Hoping I can tap into some old school knowledge here. I recently picked up a Boyer-Schutz burnishing tool, size 00C for a 5/8" turret (http://www.boyar-schultzsmt.com/burn...ller-c-3kn.htm). Originally my thought had been to see if I could adapt it for use on a tailstock, but shortly after purchasing it I found a turret that I should be able to adapt to my lathe, eliminating the need for that modification. Turret should be here early next week, then getting it mounted on the lathe will be another project.
I can't really find much info on setting up a burnishing tool. I've got W&S's Turret Lathe Operator's Manual, which covers box turning tools with rollers but not burnishing. The material I am hoping to burnish is Nickel Silver, and my goal is to bring it to final size, achieve a good surface finish, and slightly work-harden the surface. I'm thinking to turn the stock to about .0005" oversize using a box tool, then run the burnisher over the surface. From what I understand the rollers on a box tool can have a slight burnishing effect, but from what I'm reading in W&S's book there really shouldn't be much pressure on those rollers (enough to stop with finger pressure). Without much pressure I can't see the really good surface finish or the work hardening happening (correct me if I'm wrong). So how do I set up a roller burnisher? I've got 3 independently adjustable rollers, what's the process to keep things aligned? Do I bring all the rollers in to just touch the work, then adjust only one roller until I get the size I need? I can't see trying to adjust all 3 rollers evenly being a practical solution. Is there any concern with that method that it may cause a taper or the burnishing to be out of round? And do I need a small chamfer to lead the burnisher onto the surface?
TIA
Tom
TIA
Tom
