Help with steering wheel taper
  • Help with steering wheel taper
    When I brought my mill home last month, the quill handle disappeared on the ride home. I thought a boat steering wheel would make a nice quill handle. The continuous circle on the outside of the wheel should offer more control and convenience than the straight shaft handle that was on there originally.
    The wheel I got is supposed to have a "standard 3/4 inch taper". Unfortunately, I can't find a standard specification for a 3/4 inch steering taper.
    If possible, I'd like to find a standard spec for this taper to aim for before I start cutting test tapers. Any help is appreciated. Thanks.
    Taper is often referred to in inches per foot, so in your case that would be a .75 inch reduction in diameter for every foot of length. Fortunately for you this is also the taper used in pipe threads. The angle of taper from shaft center-line would be 1*,47'
      If the diameter of the wheel is to large, it might get in the way of some setups.
      I find myself having to move the handle sometimes when the table travels.
        I had thoughts of one of the wheels from HMS Victory.
        How about stuffing some playdough in the taper and then eyeing it up.
          The taper dimension is just as described, it is the taper itself.
          If indeed it is a 3/4" per foot taper it can have a start diameter of 0 up to infinity, choose wisely.
            Mission accomplished!
            For future reference "standard 3/4 inch taper" when referencing boat steering wheels and shafts is about 2°, which works out to about 0.4 inch per foot if my math is right. So not a 3/4 inch per foot taper.
            My tools available for measuring this were lacking (or maybe it was my ability that was lacking ), so I eyed it up and cut on a piece of scrap until I got it right.
              I find "standard 3/4" taper" ambiguous. Does it mean "standard taper" (i.e., one in twelve on diameter—or one in ten in lands where they speak metric) on a 3/4" diameter shaft? Or does it indeed mean 3/4" per foot on any any shaft size you happen to have?
              As a matter of interest, what is the diameter of the shaft you're fitting the steering wheel to?
                I wasn't starting with a shaft. I was starting with a shop made coupling to fit the quill input shaft. The major diameter of the taper I cut was about 3/4".
                It seems like the "standard 3/4" taper", at least as far as boat steering wheels are concerned, is a 3/4" shaft cut with an approximately 2 degree taper on the end.
                  3/4” per foot sounds sensible
                  mark
                    mark
                    Yes. Sounds very sensible.
                    Try telling that to the people who make boat steering wheels, though.
                    Unfortunately, not correct for this application.
