In the spirit of some machining related post, I thought that I'd show a project that I've completed recently.
Last year, I did the same mod to an L-W dividing head. Unfortunately, it used an odd ball collet (can't remember what it is right now) of which I only had one 1/2".
Also, didn't like the thread on chuck.
This one is a Hardinge. It's 4:1, reduction. It uses 5C collets and has the 4* taper nose as my lathe, so it can use all my chucks.
Driving the unit is a NEMA 23 motor with a 25:1 planetary gearbox driving the 4:1 head, effectively 100:1.
So far, I have not cut any gearing, but I did put a CAM indexing plate on it an it is accurate and repeatable.
The controller is Arduino based. A member on another site did the code work for it, and advised me on components, all of which are available on Amazon.
I'd guess that I have less than $100.0 between the motor and controller hardware.
